20% OFF
Fairphone 4 Battery
The original Fairphone 4 battery combines all-day power with fair materials. Long-lasting all-around.
€29.95 -20%
Pay with
notify me
Find a store
This item is out of stock
Invalid email address
notify me
Fair materials
We're working with the Fair Cobalt Alliance to integrate fair cobalt and responsible lithium into the supply chain.
Fast charging
Even when you're at 0%, this battery jumpstarts you to 50% in 30 minutes.
High capacity
Retains 90% of its original capacity even after 547 charges (full cycles).
Description
The Fairphone 4 battery holds all the power. Literally. Even when you’re low on battery, you’ll get up and running within half an hour.
With a 20W minimum charger, you can jumpstart your battery back to 50% of its capacity within 30 minutes. And the battery will keep 90% of its original capacity after being charged 547 times. Overall, your battery will last about 13 hours with phone calls. Keeping you going all day long. But the best part is that we’re working with the Fair Cobalt Alliance to integrate fair cobalt and responsible lithium into the supply chain. Now that’s long-lasting.
Good to know: the nominal capacity is 3905 mAh/15.03Wh, and the nominal voltage is 3.85V.
Technical specifications
Compatibility
Only compatible with Fairphone 4.
Product dimensions
Length: 91.9mm
Width: 46.8mm
Thickness: 6.2mm
Weight: 63.7g
What is in the box
Battery and Health and Safety Guide
See more specifications
Do not buy a battery unless you absolutely need one. If your battery is older than two years, and if your battery is not holding power like it did, then purchasing a new battery is probably the best way to go.
If you are buying a new battery to solve issues related to charging, phone stability, or the phone not switching on, we would recommend reaching out to our customer support desk first. They will be able to confirm if the battery is at fault, or if it is something else that needs to be looked at.
My phone doesn't switch on anymore. Will a new battery solve this?
It would be better to talk to customer support first, before buying a new battery.
There seems to be a charging issue with my battery. Should I buy a new battery?
While it could be a battery issue, it could also be something to do with the USB-C port on your Fairphone. Talk to our customer support for more help.
My phone keeps switching off randomly. Is there a problem with the battery?
This could be related to a number of other factors. Our customer support desk should be able to help you pinpoint the exact problem.
My battery doesn't seem to hold charge for as long as it did when I first bought it.
If your battery is older than two years, chances are it needs to be replaced. Batteries start degrading after two years of continuous use. Reach out to our customer support desk, and they will help you do a battery test.
My battery is more than two years old and isn't working as well as it did.
A new battery should solve your issue. Batteries start degrading after two years of continuous use. Purchase a new battery at the soonest, and watch your Fairphone speed up in real time.
Reviews
No reviews yet
