NEW
Fairbuds 2
Our latest generation of wireless earbuds makes a solid impact from day one and keeps going for years to come.
  • Rich, high-fidelity sound with LDAC* support
  • Long-lasting modular design with 7 replaceable parts
  • LONGTIME®-certified with warranty up to three years**
€119.00
3-year warranty 14 days return policy Find a store
Fairbuds 2 was added to cart.
Accessories for Fairbuds 2
4.6/5
1 meter
2.5 meters
One cable. All your devices.
Invalid email address
4.3/5
30W USB-C Fast Charger
Compact. Universal. Long-lasting.
4.5/5
65W Triple-Port Fast Charger
Say hello to your one-stop charging solution
4.1/5
iFixit Precision Bit Driver with Torx T5 Bit
Natural sound profile with 11mm bio-cellulose drivers
Exploded view of a Forest Green Fairbuds 2 earbud: the ear tip, the 11 mm driver and the open shell
Improved noise canceling up to 45dB
A woman in profile against a pale green wall, wearing a Forest Green Fairbuds 2 earbud
Customizable EQ with four presets
A Fairphone showing the Fairbuds app, with the earbud battery levels and the EQ presets
Up to 40 hours total battery run time ***
The Fairbuds 2 charging case in Forest Green, lid open, with one earbud lifting out of its slot
Save up to six devices with multipoint connectivity
Two Forest Green Fairbuds 2 earbuds beside a green Fairphone with its screen on
Safer for your skin with PFAS-free exterior
A man with curly hair in a beige sweater wearing a black Fairbuds 2 earbud, in front of a blue lattice
IP54 dust and splash resistant
Two Forest Green Fairbuds 2 earbuds among water droplets and specks of dust
LDAC support for high-fidelity audio *
The Fairbuds 2 charging case in Forest Green, lid open, with one earbud lifted out beside it
Hear every detail
    Stream your music at up to 990 kbps with LDAC* support. That’s three times the sound quality compared to standard Bluetooth codecs, offering a much better listening experience.
  • Engineered by audio professionals
    Tuned by acoustic engineers at Form Follows Frequency, the Fairbuds 2 packs 11mm bio-cellulose dynamic drivers that offer deeper bass, warmer mids, and clear highs from the get-go.
Active noise canceling
Enjoy up to 45dB noise reduction with active noise canceling, paired to a six-mic array to better handle wind, environmental, and background noise.
Dual-point connectivity
Seamless connectivity
With Google Fast Pair and multipoint connectivity, get connected in seconds, save up to six devices and easily switch between two active devices when needed.
A phone showing the Fairbuds app: battery levels for both earbuds and the case, and the equaliser presets
Tailor your sound
Find the right audio profile to match your vibe with the Fairbuds companion app.
  • Five-band adjustable equalizer
  • Four expertly crafted presets
Battery that lasts
  • Up to 8 hours of playtime on a single charge***
  • Up to 40 hours of total playtime (with charging case)***
  • Charge for 10 minutes to get 2 hours of playtime
With replaceable batteries in the earbuds and charging case, you can keep your Fairbuds 2 going for years to come.
Built for your everyday
  • Durable and comfortable
    Now lighter than before with stronger magnets inside the case for a more secure fit.
  • IP54 dust and splash resistant
    Be it a quick workout or your daily commute, the Fairbuds 2 are perfect for you on the go.
  • Warranty up to three years**
    Get extra peace of mind with extra warranty coverage.
LONGTIME® certified
The Fairbuds 2 are the world’s first earbuds to be certified by the independent European label because of its high repairability.
Certification
Extend your journey
With seven replaceable spare parts, the Fairbuds 2 gives you seven excellent reasons to choose repair over replace every time. Take it apart in seconds using a screwdriver and your fingers and swap what you need.
Modular, user-repairable design
Real impact, by design
We don’t just assemble parts. We respect the people and the planet behind them. No secrets, just progress.
2,083 tons
of CO₂e avoided in 2025
$1.25M
paid in living wage bonuses since 2019
30 tons
of e-waste collected in 2025
30% lower
product carbon footprint
Explore the impact Fairphone makes every year
Included in the Box
  • Fairbuds 2
  • Charging case
  • Earbud tips (3x)
  • Quick Start Guide + Safety & Warranty Information
We stick to just the essentials to reduce possible e-waste. Looking for a charger or a cable? Choose from our line of accessories below.
Reviews
No reviews yet
Frequently asked questions
We are widening our ecosystem! The Fairbuds XL was Fairphone’s modular audio debut, an over-ear headphone. The Fairbuds 2 brings that same longevity-first philosophy to a true wireless, in-ear form factor, building on the original Fairbuds.
Yes, the Fairbuds 2 connect via standard Bluetooth and are compatible with both iOS and Android devices. The companion Fairbuds app and full feature set (presets, EQ, firmware updates) require the app, available for both platforms.
None! The Fairbuds 2 are designed for a tool-free, glue-free battery swap in both the earbuds and the case.
The Fairbuds 2 battery replacement kit is €9.95, and the charging case battery replacement is €12.95.
Yes! In case of loss, you can buy a charging case core for €29.95 as a spare part.
Yes! You can purchase a single replacement earbud instead of buying a whole new pair, so a lost earbud doesn’t mean starting over.
Repair guides for the Fairbuds 2 are available on the Fairphone website as well as our YouTube channel, walking you through steps like replacing the earbud or case batteries.
Across Europe, the Fairbuds 2 are available on Fairphone.com as well as through select European retailers, operators and resellers.
We do not have a system of that kind in place yet. In case that changes, we will notify our Fairphone community as soon as possible!
Yes, your warranty stays valid even if you move, as long as you have your proof of purchase and registration on hand.
The 3-year warranty covers manufacturing defects and faults outside your control. Swapping a worn battery or a user-replaceable part yourself is a repair, not a warranty claim, and won’t affect your coverage.
The Fairbuds 2 are crafted with 48,6% fair and recycled materials including plastics, rare earth elements, tin, cobalt, copper, gold and silver, and produced under fair working conditions as part of Fairphone’s Living Wage Bonus and Workers’ Voice programs. Fairbuds 2 is also e-waste neutral.
The Fairbuds 2 are designed for daily wear from cleaner materials. We pioneered the use of PFAS-free and more than 75% post-consumer recycled material, keeping persistent chemicals off your skin and choosing smarter materials for the planet.
For every Fairbuds 2 unit sold, Fairphone collects and recycles an equivalent weight of e-waste elsewhere, offsetting the product’s own eventual waste footprint.
Yes, the Fairbuds 2 already meet and exceed the direction of the EU Batteries Regulation, which will require user-replaceable batteries in portable devices from February 2027. Wireless earbuds have not been named in the current exemption list, so much of the industry may eventually need to catch up to where the Fairbuds 2 already stand!
* LDAC and LDAC logo are trademarks of Sony Corporation. Improved LDAC performance is currently only available on Android devices.
** Warranty T&Cs apply
*** Battery runtime indicated is with Active Noise Canceling off
