20% OFF
Fairphone 4 Display
What's a smartphone without a display? Luckily, you can replace it yourself.
€79.95 -20%
Pay with
add to cart
Delivery: 2 - 5 days (from €3.95) Find a store
Easy to fix
Easily accessible for a quick fix or swap. Takes seconds.
Scratch resistant
Made with built-in drop and scratch resistance. Made to be strong.
Fair materials
Increasing the amount of recycled magnesium in the LCD display.
Description
The Fairphone 4 display is bright, sharp and easy on the eyes. The replaceable 6.3’ Full HD+ screen with Pixelworks technology makes for an immersive viewing experience that's protected against drops and scratches with Corning Gorilla Glass 5. Now, that's long-lasting.
It comes with a grey or green protective rim to complement the sleek aluminum sides of your Fairphone 4. Stylish has never looked so good.
IMPORTANT: Your new display may include a plastic protective sticker for the Front camera opening. Make sure to remove this sticker before mounting the display.
Read our support article for this spare part here
Technical specifications
Compatibility
Only compatible with Fairphone 4.
Product dimensions
Length: 157.4mm
Width: 70.9mm
Thickness: 7mm
Weight: 57.6g
Color
Grey or green
What is in the box
Display and Health and Safety Guide
See more specifications
Reviews
No reviews yet
