Fairphone 3 Display
What is a smartphone without a display? Luckily, you can replace it yourself.
Easy to fix
Easily accessible for a quick fix or swap. Takes seconds.
Scratch resistant
Made with built-in drop and scratch resistance.
Phone compatibility
Made for the Fairphone 3 and 3+ only.
Description
This display module is fitted with a 5.65 inch Full-HD display and a 18:9 ratio for a bright, sharp and easy on the eyes experience. While Gorilla Glass 5 provides greater scratch resistance in case your phone takes a tumble. Now, that's long-lasting.
Read our support article for this spare part here
Technical specifications
Compatibility
Compatible with Fairphone 3 & 3+ only.
What is in the box
Display, Health and Safety Guide
Zie meer specificaties
Reviews
No reviews yet
