Sin categorizar
Repairing the new Fairbuds XL
Sin categorizar
It has been a month since we dropped the new Fairbuds XL, and the response has been terrific so far. Armed with new speaker drivers that provide a better sound experience than before and a more breathable, plush fabric option for the ear cushions and headband, the refreshed Fairbuds XL offer more comfortable listening all round. They are still just as repairable as their predecessor as well. All you need is time and a screwdriver. Here’s how you swap out parts on the new Fairbuds XL and keep them going for years to come. Meet premium sound that’s truly built to last.
Replacing the Fairbuds XL Speakers
You deserve great, powerful, clear sound. But if your speakers sounds off, it’s hard to get lost in your music. Luckily, this essential part is replaceable. If you already own a pair of the original Fairbuds XL, we hope they’re still going strong. But if you’re looking to upgrade them, did you know the new left and right speakers are fully backwards compatible? Better sound, same headphones. That’s modularity.
Replacing the Fairbuds XL Battery
With over 30 hours of listening time, the battery on the Fairbuds XL can handle even your longest playlist. It’s designed to last over 500 charge cycles, and when it’s past its prime, you can easily replace it yourself. That way, your beloved headphones are always ready to go and you can listen as long as you like.
Replacing the Fairbuds XL Headband Base
The base of the headband does a lot of the heavy lifting in the Fairbuds XL… literally. It’s not only the connection between the headband and the speakers, but it’s also the component that carries the most weight. Without this component, you can’t wear your Fairbuds XL, so it’s handy that you can replace it when necessary.
Without the headband, you wouldn’t have headphones! It holds your Fairbuds XL together and guarantees optimal wearing comfort. It’s an indispensable component, just like the cable inside and the headband cover that wraps around it. Making all three replaceable perfectly highlights why modular design should be the future. If any of them wears out, you can simply replace what needs to be replaced instead of throwing your headphones away.
Great sound and noise cancellation are one thing, but how can you enjoy your favorite audiobook or playlist without our comfortable ear cushions? The new ear cushions on the refreshed Fairbuds XL are made from a robust, breathable fabric that’s soft on the ears and really nice to look at as well. Own an original pair of Fairbuds XL? These are backwards compatible too. And you don’t even need a screwdriver to replace them!
The new Fairbuds XL are now available on our webshop.
    Leer más
    Leer más
Boletín de Fairphone
