Sin categorizar
Sin categorizar
The latest Fairphone model wouldn’t be a Fairphone if it didn’t come with Fairphone’s signature modular design. The Fairphone (Gen. 6) lives up to its legacy with 12 replaceable spare parts, including the display, the cameras, the USB-C port, the battery and more.
The Fairphone (Gen. 6) continues Fairphone’s legacy of industry-leading repairability with a perfect 10/10 repairability score from iFixit.
What makes this Fairphone edition even more iconic is how it takes modularity beyond repair. Say hello to a new line of exclusive Fairphone mobile accessories that combine function and form perfectly. Mix and match and find a unique combination to make The Fairphone (Gen. 6) truly yours.
The Fairphone (Gen. 6) Lanyard
Keep your smartphone handy with The Fairphone (Gen. 6) Lanyard
The Lanyard for the Fairphone (Gen. 6) lets you show off your device to the world, while keeping it handy always. It’s perfect for people who don’t like to keep their phones in their pockets or bags. The textile cord attaches via a stainless steel and aluminum connection system that is screwed directly and securely to the Fairphone’s lower back-cover.  This means you can easily combine it with other accessories like the Finger Loop and the Card Holder. It also works perfectly with the Fairphone protective case or flip case.
The Fairphone (Gen. 6) Finger Loop
Your phone will never slip out of your hands with The Fairphone (Gen. 6) Finger Loop
Keep it flat when you don’t need it. Extend it when you do. The Finger Loop for The Fairphone (Gen. 6) makes sure you hold on to your Fairphone tight, no matter where you are. It’s perfect for scrolling through your social feeds, watching your shows, or catching up on some reading when you’re on the go. Especially on a crowded bus, for example. Made from recycled hard plastic and (non-recycled) silicone, the Finger Loop is easy on the eyes, and easier on your fingers. The accessory integrates into your phone’s design, replacing the lower back cover. Unscrew the lower back cover with the included Torx T5 screwdriver, and screw the finger loop into your device instead, keeping it super secure with almost no extra weight. It works perfectly with the lanyard and a protective case on, and with three color options to choose from, you can customize your Fairphone by mixing and matching colors.
The Fairphone (Gen. 6) Card Holder
Leave your wallet at home when you have The Fairphone (Gen. 6) Card Holder
The new Fairphone (Gen. 6) Card Holder means you can leave your wallet at home, fitting up to three cards that you can pull out quickly with the easy eject mechanism. With the back made from recycled hard plastic and the sides and holder itself made from soft plastic and silicone, it’s sturdy yet sustainable, couture yet comfortable. The integrated modular design means it’s part of your Fairphone, adding minimal bulk to your device. It works as a replacement lower back cover. Like with the Finger Loop, simply unscrew your existing lower back cover, and screw the cardholder in its place. And if you’d like to add a protective cover or the lanyard, you can do that as well. Available in three colors, it gives you the opportunity to customize your device with a unique color combination that’s truly yours!
The Fairphone (Gen. 6) Protective Phone Case
Stay protected with The Fairphone (Gen. 6) Protective Phone Case
Up your Fairphone’s safety and style with one simple accessory. Pick up a Fairphone phone case that’s designed to give your Fairphone (Gen. 6) all round protection. With raised bumpers around the cut-out for the iconic Fairphone camera triangle, you know your lenses are going to stay that much more protected. With recycled hard plastic on the back and soft plastic on the sides, the phone casing is built strong and super comfortable to the touch.  Choose between three color options to match your device or mix it up. It’s totally up to you. The phone case is also compatible with all the other mobile accessories available for the Fairphone (Gen. 6). Because you shouldn’t have to compromise on customizing your Fairphone just the way you like it.
The Fairphone (Gen. 6) Screen Protector
The Fairphone (Gen. 6) Screen Protector keeps your display safe from nicks and cracks.
The Fairphone comes with a durable and scratch-resistant 6.31” LTPO OLED display that’s made with tough Gorilla Glass 7i. Now keep it even safer with a special Fairphone screen protector with Xensation technology from Schott. It shields your device against everyday scratches, bumps, and drops, ensuring a crack-free display always. Easy to apply and practically invisible, the phone screen guard comes in a standard variant, and with a privacy filter that is designed to keep your screen for your eyes only.
    Leer más
    Repairing the new Fairbuds XL
    Leer más
Boletín de Fairphone
